Dynamode router has stopped working - can't figutre out why
My Dynamode R-ADSL-C4 router which has been working fine for 12 months has stopped working and I can't figure out why. The Manual could be written in Chinese for all it's worth. I powered down for 3 days while I was away from home to reduce fire risks etc and it won't re-start. "Unable to find server" when I try to access Plus Net via Firefox.
I can't locate the set up page. Can anyone remind me how to do the basic setup please?
Alecto
This any use?
holdtight
Try a factory reset and start again
Router failure
My D-Link router that has worked fine for 9 months has also stopped connecting. My old ADSL modem does work however. I have access to other routers and I cannot connect with them either. Plus Net are not aware of any problems at their end.
Can anyone comment as to whether one router is more sensitive than others to line problems ?
I think it would be fair to say that if your old modem works then the problem is probably a local issue.
maybe the router (s) is/are more sensitive to line issues than the modem.
if there was a generic connection issue with Plus Net at the moment a lot more people would be aware and screaming.
Welcome to the forums btw.
Ongoing router problems
Have you solved the router problem yet as I still have the same issue.
