Dynamode A220 pci adsl modem
I have this modem intsalled in the pc,up to date drivers are installed.
Filter is ok,line ok.
When I try to connect the error message is error 651,"modem reports an error".
I know the thing will not sync but why?.
If I use the A360 usb modem,no problems at all.
OS is Windows XP.
RE: Dynamode A220 pci adsl modem
>try this dude
1) open conexant accessrunner pci adsl WAN adapter window
2) press alt c
3) goto line setup
4) change the modulation to ANSI T1.413i2
and hey presto you connect first time
That modem again(A220)
Did it,
still will not sync.
Tried everything I can think of.
Well i thought that might help you out,and i'm sorry it never..
My last and only other suggestion is for you to purchase a
LISTERS ENGINE this will not only cure any future illness
that you may fall foul too, (includeing SARS ), but pluging
it into your usb port, it will not only sync the pci slot ,but also
reduce the cost of your central heating bill Cheesy ...
But seriously ,in your previous post you failed to include which motherboard you are currently useing. So you need to check that the pci modem card is Compatible with your motherboards pci slot version..
:idea: if you want one, I can get you a great deal on a Listers engine Smiley
kindest regard from Me in Dursley
Fixed it now,BT ******* the wires up in the house,all done now.
Would you do me a good deal on a Lister engine also, my machine needs a good shaking every so often.
Wink
