Dynamic IP?
Dynamic IP?
Hi i've registered an adsl home self install account and now i'm waiting for it to come. I was just wondering whether i would get a fix ip addresS?
And in the control panel there's a option called static IP is that for dailup only or is it for adsl aswell?
thanks in advance
1 REPLY
RE: Dynamic IP?
> thanks in advance
You will receive a static IP address, which will resolve to the address <username>.plus.com
The "Static IP" button will tell you your current IP, thoguh you can't chnage it or swtich to dynamic.
