Dropped conection
Dropped conection
Hi can anyone help, I loose my conection if I leave it alone for a little while, and even sometimes while still working on machine, also how do I get to where you alter packet size, Ta
RE: Dropped conection
You are not alone - what modem and Pc operating system/hardware do you have?
I have a similar problem and it has been outstanding since I started nearly a month ago!
With a bit of luck if enough people with the same problem club together support will find a cure
It sounds as if in your settings it is set to disconnect after a set idle time. If you tell us what operating system your on i think we can help you.
Dave Allan
I also have a similar problem....I lose connection and I have to change my username & password to the startup_user@startup_domain and then back. I have to do this a couple of times and then it seems to reconnect. The last time it did it (about 8:15pm tonight) I had to do all the above but this time it worked after I changed my plusdsl password to be incorrect & then changed it back to be correct....this then seemed to get me connected again.....this is a major pain in the rear.....any ideas ? - to me it seems as though the problem is something to do with plusnets server or my user configuration at plusnets end. I beleive this becasue the startup user connects to the BT demo page every time without fail....
Cheers folks
3com router
op sys - M.E
P4 - 2.4 ghz
256mb ram
hi trevor i had the same problem i contacted support and they e-mailed me updated drivers for my modem,i am useing xp prof.
> Dave Allan
Hi and thank's, I am running XP Pro, I have done the Dr TCP and it seems a trifle quiker. but still will not stay on.
