Drop-outs on sync
Drop-outs on sync
Has anyone else experienced prolonged drop-outs on their connection?
My setup is as follows;
Single master socket with micro-filter and BT Handset. Cat 5 wiring to extension with either D-Link/Cisco or Draytek Router (normally Draytek).
The connection drops out for prolonged periods (up to 24 hours) and will not re-connect even if all other equipment is removed from the line.
BT & Plusnet have tested connection, but find nothing wrong (other than initially low impedance caused by old telephone handset - now replaced).
Micro-filter, Extension wiring & BT Handset have all been replaced as per BT suggestion to no avail. All routers (D-Link & Cisco borrowed to eliminate router causing problem) report no sync/carrier.
Help, I'm tearing my hair out.
Evil Evil
Drop-outs on sync
I know you've done some of this already but work through:
http://usertools.plus.net/tutorials/id/10
http://usertools.plus.net/tutorials/id/13
Drop-outs on sync
Have tried all of that, many of them multiple times now. Guess I'll just have to put up with only having broadband 5 days per week until BT get things sorted.
:roll:
