Draytek Vigor 2800 Settings
I wonder if someone has produced a settings guide or such like for the Draytek Vigor 2800 modem?
Go to http://www.seg.co.uk and click the link for techsupport at the bottom left of the screen. you should find loads of setup info there.
I have used the Dreytek Vigor 2600 and now V2800 routers for about 5 years and they are probably one of the most reliable routers around, I never have to reboot my router but deal with lots of other brands that require regular reboots.
If you need any config advice give me a shout and I will try to help you.
Digitalstorm
Cheers Dig,
i will take a look and get back to you if neccersary.
Lee
