Downloading
Downloading
Hiyas.I got my new broadband today and im happy with it but i have a slight problem that maybe you cannot help me with.The problem is that i have downloaded bittorent and am trying to download a file thats about 4gb but i cannot reach anything above 5kb(s) and everyone else on the site can seem to download these files.I was told I needed to disable my firewall firstly which i done but i was also told about opening ports or something which i do not understand.I know i can download the file as i purchased a premium account.Im not complaining about your service as i think the connection is fine im just trying to work out what i have to do to open ports or whatever it is i got to do to allow the download to run faster
cheers
Jon
Downloading
hi,try this link and enter port 6881 in both to and from i think,i my self use azureus which is a bittorrent client and much easier to use in my opinion..http://www.kitz.co.uk/tute/NAT.htm
Downloading
where do i input the number cant see what i gotta do.just see a tutorial...
cheers
Jon
Downloading
sorry,u using a router ,as im using the sar 110.if so u go into the nat rule entry .
Downloading
do i disable the NAT
Downloading
no just go into nat rule entry and add another rule as discribed in earlier link
Downloading
He is using a different router (A Linksys WAG54G) so the port forwarding setup page is different to your router (which is a SAR110).
Downloading
where is info on make of router?,as if i knew i wouldnt of given info on a diffeant model :?
Downloading
here.
Downloading
the cd that came with the router? it contains the full user manual, it is also available to download from the LinkSys website.
however, to make things simple
open up your web browser
type in 192.168.1.1 or if you have changed it from default, use that
default login and password is admin/admin (I hope you have changed these just incase)
click on applications and gaming
here you will find the pages for single port forwarding and range port forwarding.
as the names suggests, the single port forwarding page allows you to set up a single port for forwarding, the range port forwarding allows you to setup a range of ports for forwarding like 6881-6990 for example.
remember to click on save settings before going to a new page.
