Downloading speed by ADSL
AskASQLguru
I was downloading one program for which the speed shows only 50K per second which is only 20% of the designated speed. I believe it should be 250 kbps.
Could the customer support clarify this issue for me.
TIA
1 REPLY
RE: Downloading speed by ADSL
Evening,
If the program you are downloading the file in is showing 50K Bytes per second then this is about right, the connection is 500K bits per second (Kb rather than KB).
Kind Regards,
Duncan
