Download speeds a joke!!
Just done speed test after internet felt slow 567kbps wheres my 2956kbps download speed gone :twisted: . Rebooted router checked exchange (green). Plusnet are always getting slated on ispreview.net I no wonder with speeds like this give back my stable 2mb connection instead of Plusnets so called ADSL Max link:censored Evil
[Moderator's note by James - (sallyandjames): Bypassing Swear filter removed : link:rules ]
ady
well check ur stable rate first
http://www.plus.net/my.html?action=stable_rate
its prob ur bras profile going down to 500kb after a dodgy synch rate
8000 Kbps Wink
..then check your BT profile speed.
3000kbs Wink
Run this speed test please. > http://www.adslguide.org.uk/tools/speedtest.asp
BTW
You have stated that the BT profile is at 3000kbps, but what actual throughput did you acheive with the BT test?
