Download speed
Download speed
I seem to only get fast-ish downlaod speeds at peak times even though thats only around 150kb/s...
At off peek times my download speed is terrible at about 40kb/s but i can stream videos fast etc.
Heres my statistics
System Up Time 141:57:28
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoE 242144 434776 0 200 4899 35:22:12
LAN 10M/100M 71439 76776 0 111 28 141:57:24
WLAN 11M/54M 2433430 1582719 0 6177 466 141:57:15
ADSL Link Downstream Upstream
Connection Speed 4928 kbps 448 kbps
Line Attenuation 38 db 11.5 db
Noise Margin 7 db 21 db
Any ideas please?Huh
Download speed
What is your data transfer rate set to: connection settings -> high speed broadband. Given your sync speed this should be 4000 -> 4500.
Are you connected via wireless or wired. If wireless, do you get similar speeds if you connect via a wired connection.
Also do you mean 150 Kbits/s or 150 KBytes/s?
What are you using to measure the speed.
Do a BT speedtest when things appear to be fast and when they are slow and post the results.
Download speed
When i download something from download.com for example and the download box comes up it says: 150KB/s for peak time and 45KB/s off peak thats wot i am goin by. I used to get about 250KB/s so i am assuming thats kilobytes??
Isn't the downstream connection speed to sync speed? because i am using a wireless router so i dont get those sync arrows so i cant chek there in my taskbar.
Account Name
Firmware Version V4.01.06
ADSL Port
MAC Address 00:18:4d:67:2d:cb
IP Address 87.113.76.241
Network Type PPPoE
IP Subnet Mask 255.255.255.255
Gateway IP Address 195.166.128.72
Domain Name Server 212.159.6.9
212.159.6.10
LAN Port
MAC Address 00:18:4d:67:2d:ca
IP Address 192.168.0.1
DHCP On
IP Subnet Mask 255.255.255.0
Modem
ADSL Firmware Version 6.01.00.12
Modem Status Connected
DownStream Connection Speed 4928 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
Wireless Port
Name (SSID) NETGEAR
Region Europe
Channel 11
Wireless AP Enabled
Broadcast Name Enabled
Download speed
Loys of things can affect your speeds so I'll ask again...
A wireless connection can affect throughput speeds even though ot runs at 54Mbs. What speed do you get if you connect wired.
What does the BT speedtester say your speed is? Also try some of the other speed test sites like thinkbroadband and report what you get.
Download speed
I tried a wired connection and thats still the same.
BT speed test
The speed test has completed on test server speedtester1.nat.bt.com for user *********** and you have downloaded a 1.7Mb file at a speed of
1959 kilo bits per second (Kbps)
I couldnt find that connection settings thingHuh where is it please iam using windows XP Pro
Download speed
It is on this website on the left menu under My Account.
If that says 2000 raise a ticket and get it corrected, it needs to be 4000 -> 4500 for your sync rate.
Download speed
i raised a ticket how long will it take to be changed please?
Download speed
No idea, I don't work for PlusNet.
It may not be investigated until Monday/Tuesday I would guess unless one of the comms guys monitoring this forum can do something sooner.
Plusnet Leader
Plusnet Leader
Download speed
I can see one of my colleagues made some changes to your account yesterday afternoon.
After rebooting your router you should start to see an increase in your speeds.
If this is not the case, don't hesitate to let us know.
