Download and Upload Speeds
cookie141
My download speed is 57kbps where my u/load is 233kbps..I am connected @ 576,000bps.I have a Conexant Access Runner PCI Adsl Wan Adapter installed..I have reinstalled and upgraded the drivers to the latest ones..I have not changed any settings on the modem from what they were originaly
Did not have this problem a few days ago until I upgrade my account so I could go Peer/Peer for d/loading music.
Any suggetion to the prob would be grateful
Cheers Cookie
Cookie
cookie141
RE: Download and Upload Speeds
> Cheers Cookie
> P.s I am running Zone Alarm Pro
> Cookie
Well mate you lucky,
getting 57kbps per second,
At the moment My modem refuses to hit above 35k,
im a very unhappy person Sad
57kbps sounds about right on a 576,000bps port speed setting,
IBY
> Cheers Cookie
> Cookie
> Cheers Cookie
> Cookie
Do you mean Bits or Bytes? as theres a big difference, as theres 8 bits too a byte. So if bytes then that's the average download speed on test sites
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
Usually in #utgames #utchat #uthelp
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
cookie141
> I mean Bits
> Cheers Cookie
> Cookie
