Download Speeds
Download Speeds
For the past few days my download speeds have gone down to a crawl.
I e mailed Plus Net who ran a check and informed me that everything was fine.
Sometimes briefly the speed will go back to what it was before and then you will sit there waiting and waiting.
Iff this continues I think that I will be looking for another ISP.
Download Speeds
Try going to "connection Settings" after you sign in to your PN account and follow the instructions for the Broadband Fault Checker . It requires that you connect using a different name and do the check at certain times of the day /night .
Craigiusmaximus
Download Speeds
What/where are you downloading from on a torrent or limewire or something else?
