Domains.
Domains.
Hello all,
I have just transfered a Domain to PN <well pointed to the DNS servers to PN> - PN support have kindly confirmed this was done.
But I'm a bit baffled.
I really want this particular Domain for mail - therefore I wanted to create a POP3 account using this domain <anything@anything.co.uk> but when I go into My Portal > Email Settings > Configure Mailboxes > Add Mailbox I basically can setup a new Mailbox, but with my "default" @<anything>plus.com email address. -- There doesn't seem to be an option to select what 'Domain'
Can I not configure a Mailbox using my OWN Domain ?
If not, how do I redirect all mail that goes to <mydomain.co.uk> to a particular pop3/email address.. Maybe I'm being thick... :?:
Get me? :roll:
Thanks all.
Glen
Domains.
Any domains hosted work hand in hand with your @username.plus.com address.
IE, if you setup the mailbox testuser@username.plus.com, the address testuser@domain.com also goes there.
If you setup a redirect another@username.plus.com, then e-mail for another@domain.com is also forwarded there./
Domains.
Ahh! I get it now! I didn't realise it worked like that... thanks! Tongue
Glen
[Moderator's note (by acarr): Removed quote containing the entire contents of the previous thread. THis only makes a mess]
