Domain Names and CGI Subdirectories
Hi
I've looked through th forums etc trying to find a method to do the following:
Have a domain name point to a subdirectory on the cgi space, as is possible with the non-php webspace as in:
One Domain point to htdocs/whatever
Another points to htdocs/whateverelse
I would like to be able to do the same pointing to user defined directories on the cgi servers.
I understand that you can set the www as a cname to criticalmass, but this means pointing to the root dir.
At present, I'm doing nasty redirects, and I rather not have to.
The only alternative I see is obtain additional cgi subdomains, but I'm not quite clear on how this will work in practice.
(Oh, and I don't mean subdirectories from cgi-bin, but from root of userdir)
Comments?
1 REPLY
RE: Domain Names and CGI Subdirectories
<snip>
Apologies for posting this in the wrong forum - got slightly lost!
Jak
