Does Anyone Know how long BT take to do the Whoosh test?
Hi All,
I have just decided to apply for Plusnets reasonably priced self-install and was wondering if anyone knows roughly how long Bt tend to take to carry out the 1st Stage line check to make sure the point-to-point distance is within the radsl limits??
I havn't been told..only how long it might take for line activation..which is all well and good if i pass??
Any help appreciated as i am panting at the prospect of having adsl at home (currently have at work but what fun can you have at work?)
regards
RE: Does Anyone Know how long BT take to do the Whoosh test?
Just a quick follow-up..received confirmation that im within range..so thats cool!
Now does anyone know where i can get a few microsplitters cheap?? luckily i am borrowing a speedtouch usb modem from work (we went over to router version)..?? Smiley
> Hi All,
> regards
http://www.action.com/uk/apps/productpresentation/index.php?product_id=ADSLSPLIT
They're only £7 each, don't think it's going to break the bank.
Angus
technogogo
also www.seg.co.uk
They supplied me with 3 splitters the day after I ordered them.
> Angus
> also www.seg.co.uk
> > Angus
Well in the end I went to a company called solwise and bought a few splitters and an rj11 to BT converter..that is all in place now...Modem ready..all the lights are GREEN! I think this indicates BT have done there part..but When i spoke with Tech support, they said cant do anything until BT have confirmed it all..argh..so close..especially as i have phoned and cancelled all my existing ISP and BT surftime..typical eh??haha well i hope bt do it quick now!!!! else i wont be getting my internet for days!
Sorry BT have not completed finishing off your ADSL activation. As soon as we have any further Information we will be back in contact with you.
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Technical Support ................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
> Kind Regards
> Kevin
Just for your Info as well, managed to use the bt test account BT_TEST_USER@STARTUP_DOMAIN and got a connection with an IP address assigned to me..i know this isnt conclusive proof, I suppose but just goes to show the BT wheel turns very slowly!
