Do you think I can get 1mb with these stats.
DS - 50db
US - 63db
I think my downstream is ok (but not great), but will the upstream of 63db have an effect on if I can 1mb?
The upstream is the same as when you had 512
Usually upstream attenuation is lower than downstream, and it's the downstream value that determins your acceptability for a specific ADSL speed so those figures do look unusual. Does you router give you any other info, if so please post that including the descriptions for each value.
