Do I need filters?
Do I need filters?
Heya,
Just got my ADSL line activated and my Cisco Router is showing the ADSL line is not active.
Ive nicked a spare telephone cable to plug into the router to the wall socket. The line is a single socket and no phone will be required (small four by four room with lots of loud server and barely enough room to move)
Anyways, I know you need filters IF you use a phone, what about if not. Cos if you dont, then my line is bad. OR, is the phone cable crossed or something?
Cheers
AJ
(CCNA, not a broadband engineer, yet)
Do I need filters?
No you dont require a filter as that is only for filtering the phone.
I asume you have set the router up correctly and the line is active
Do I need filters?
PlusNet say the line is active, the tracker says so.
However, plus have said alot of things.
Tommorrow is not going to be a good day me thinks.
Cheers for the info, didnt think I needed filter.
Ianwild
Do I need filters?
There are two types of modem lead, one works and the other doesn't. Does the one you have just have two contacts on the Rj-11 side, or is there more?
Cheers,
Ian
Do I need filters?
Interestingly enough I tried another lead (the previous lead was from a fax machine) and we are flashing the transferring.
Now, to work out how to configure it with the pix and routers, Sad
Cheers
AJ
