Do I actually have a Static IP?????
When I look at my ADSL account details, it says my IP is server assigned, yet when I click on Static IP, it says I have a static IP. Anyone know which it actually isHuh Or should I raise a query with Tech Support
Both are actualy true.
You have a static IP. However, to save on configuration, the systems at PlusNet assign your machine with the same IP each time you connect.
That clears it up, Thanks!
