Dlink 604+ physical line error
I have been using a Dlink 604+ wireless router for 3 months but recently I have been losing my connections with a physical line error displayed (3 times this week) I know this isnt a Plusnet problem because I was having it b4 I migrated from Nildram. I use a conetexant 4 port router as a back up and this syncs and works fine so I have contacted Dlink who said update to the latest firmware as it less fussy about the line quality, this made me suspicious of this fault that the router is fussy about line quality and it is a problem with the router, only prob is I have latest version.
Next was told to get the line checked possible for noise, I have a BT engineered installed DSL socket so It is not a filter problem because I dont have 1Smiley
so do I need to raise a ticket or go to BT I have used 151 auto system which says I dont have a problem with the line?
1 REPLY
For detail on the router try the forums at;
http://www.expansys.com/forum.asp?code=DSL-604GPLUS&page=1
I have found them very useful. As this route comes with no real documentation.
Chilly
