Disabling Static IP
Disabling Static IP
How do i disable static IP?
When i goto the static ip page in My Connection it reports i am using a static IP. I only have one CLI number and I was under the impression that i should have a dynamic IP from Plus.Net if this was the case...?
Any ideas?Huh
1 REPLY
RE: Disabling Static IP
Hi There. I tried to do the same thing, but it appears that with ADSL you have to have a static IP. That is what I was told by Plusnet, so the option to change it doesn't appear in control panel. Hope this helps.
Regards, John Taylor.
