Different IP
Different IP
Hi, i asked PlusNet through the Web assistant if they would change my IP address for me (I'd tell you the reason but i've just writ it all out to PlusNet and cant be bothered again). Does anyone know whether PlusNet would change the IP? And if they'd do it free of charge? Thanks.
Zathras
Different IP
If youre on payg you could connect to the new RIN and get a new IP every time Cheesy
other than that Ive not seen anyone get one on here.
Plusnet Staff
Plusnet Staff
Different IP
Changing IP addresses generally isn't something that is done very often and will be judged on a case by case basis. Simple reason is that if we change an IP address can we re-allocate it to someone else (for example we wouldn't want to re-allocate an IP that was being constantlyDDoS'd).
