Dial-up Modem Speedup with ADSL
I ordered ADSL two weeks ago.
Last week ADSL was enabled, now I'm just waiting for the router.
For 3-4 years I've put up with a dreadful AOL connection using a dial-up modem, with speeds averaging around 5-10Kbps. BT have even rewired up to the master socket.
Now that ADSL has been enabled, my modem is absolutely flying! I bet it was just the 3K filters in the exchange causing the modem to slow down. The ARQ light never used to stop blinking, now it never blinks.
1 REPLY
RE: Dial-up Modem Speedup with ADSL
Very strange that Ivor.
It is usual when your line is ADSL enabled for it to slow down by a small amount.
Mine went from 42k to 36k after ADSL.
And others have reported similar in the past.
A fault must have been cleared in the exchange when they wired you up to the ADSL rack?
Regards
http://www.hmrg.co.uk
