Debugging ADSL connections
Yeah well, it's been a week since BT activated the line and a week of plusnet ignoring that I can't connect so here we are...
I have a Voyager 105 modem. It occasionally trains then gives up. The Status tool says no signal. Can anyone recommend some software or instructions to help debug or log what's going on here? I use XP.
1 REPLY
Should you be interested, Kitz has lots of good info
http://www.kitz.co.uk/adsl/frogstats.htm - down the bottom
