DSL tweaks
DSL tweaks
Found this prog at www.speedguide.com
Name of program: SG TCP optimizer
Settings:
MAX MTU:1500
TTL: 64
TCP 1323: Windows scaling
TCP RWIN: 13140
mtu discovery: yes
Blackhole: no
Selective ACKS: yes
max dupe ACKS: 2
Made a big difference to my connection upload&download.
RE: DSL tweaks
> Settings:
> MAX MTU:1500
> TTL: 64
> TCP RWIN: 13140
> mtu discovery: yes
> Blackhole: no
> Selective ACKS: yes
> max dupe ACKS: 2
Hi
Just thought id let everyone know that its http://www.speedguide.net
And he's right about the speed, The speedtest rates me at 494Kbps! Which i think is the fastest its ever been! Thanks kev for pointing this out. Its well worth a download.
Andrew
RE: DSL tweaks
Ooops....
sorry about the website address,must have been asleep.
Anyway,I've tried a few different progs but that one seems to work.
RE: DSL tweaks
You probably didn't have ADSL in October when every ISP had speed problems. All were down to the MTU setting for the BT network.
BT recommended a MTU of 1458 to avoid packet fragmentation through its network. What you will find with a setting of 1500 is its slightly faster when the network is lightly loaded, but when there is high traffic your speed falls dramatically.
This is also identified on the speedguide site at this link:
http://www.speedguide.net/read_articles.php?id=156
May have a play at increasing the RWIN to see how it goes, as mine set at 17016
RE: DSL tweaks
A lot of programs will not let you set the MTU to 1458,the nearest is 1500.
MTU of 1500 on mine is ok,at peak times I get the same as off peak.
The RWIN setting that I use works ok.
RE: DSL tweaks
> Settings:
> MAX MTU:1500
> TTL: 64
> TCP RWIN: 13140
> mtu discovery: yes
> Blackhole: no
> Selective ACKS: yes
> max dupe ACKS: 2
may try it but a question i have is, ive always had between 55/60 speed for dl's and the only thing ive changed is the mtu to what it is now 1458.
so iam asking would this make a significant change to my speeds,or basically what were ur average speeds before you got this proggy.
only problems i get is i get a few disconnections, by that i mean the adsl runner just kicks me off completly ( connaxant usb adsl modem), can be very annoying at times, and nothing ive ever done has stopped it either (and ive tried loads)
