DSL or MAXDSL?
DSL or MAXDSL?
Anyone know whether it's possible to determine what service you are connected to, and if so, how?
1 REPLY
Alecto
DSL or MAXDSL?
You can ask Plusnet who should know.
Or get your line stats out of your router/modem (google the model number, or look in the manual to find out how).
Then look at your UPload sync speed.
If it's 448k, you're on max, if it's on 228k (or something very near, but I think that's the right figure), you're on the basic fixed speed service.
Higher than 448k and you're on the LLU service using Tiscali.
