DSL TEST on dynamode a360 usb modem
anybody got this test to run on this modem :?:
This topic seems to be proper to the ADSL forum and has been moved here.
John Essex Forum moderator
which test?, you mean the one that comes with the A360 modem, i havnt, i keep getting error "correct DUN name not found"
yes that the test wot is that p88 dun not found
What you on aboutHuh
There IS no test that comes with the A360 USB modem.
If you download the drivers from Plusnet, then there is an exe file called DSLTEST. Is this what you are talking about?
"If you download the drivers from Plusnet,"
why download drivers from PlusNet for the A360 modem?
The drivers are the same as on the CD.
There are no new drivers.
Dynamode sent me the so called new drivers and they are the same as on the cd and on plusnet.
I downloaded them because I thought they were the new drivers also.
Even the Windows XP drivers are not XP drivers for that modem.
There are no Windows XP drivers,just Windows NT/2000 ones.
It says for Windows XP but they are not written for xp.
You are not meant to run DSL test.EXE
it runs as part of the modem setup/installation.
It checks the line and a few other things and should not/cannot be run on it's own.
It is on the install CD as well and runs when you install the modem.
If it was meant to be used on it's own then it would be installed and would be on your Hard drive.
It is not and and cannot be installed as it runs from the driver installer.
ok thanks was just wondering as been having drop out from exchange and saw test and ran it thanks again
