DSL Connect
DSL Connect
Hi
I would like to hear from anyone who is using the service DSL Connect
Questions
1) How good do you find this service
2) Do you find it quicker than a dialup connection
3) Have you had problems with slow connections, downloads
4) In general is the service any good
The reason I am asking is because I have just changed over from dialup to the DSL Connect, I am told it is provided by an outside agent and not Plusnet.
If you have had problems please let me know.
Thank You
dwas :?: :!:
DSL Connect
You will probably get a quicker reply to your questions if you do a search for 'DSL connect' on the forums.
The 3rd party is Tiscali in case you were wondering.
PlusNet are no longer actively promoting the DSL connect product now their broadband lite product is available at the same price £14.99.
DSL Connect
Thank you for that Peter, I thought it was Tiscali.
I had only just signed up for DSL Connect when I found out Plusnet no longer promote the product. Now I am waiting to see what happens next. The connection speed is so poor its not true, from speed tests recorded last night using ADSLGuide. 22kbps, 22kbps, 24kbps. :x
