DRTCP
eglwys
DRTCP
Hi all
Ive just got my ADSL and so far so good all up and working with no apparent problems at all.
After reading a previous post I tried running DRTCP to set my MTU. Unfortunately it only recognised my 1394 Firwewire and a TV adapter which I don't think I have. I am running WinXP With a Alcatel Speedtouch PCI modem Which my system recognises as an ISDN adater.
Any Ideas?
Thanks in advance
Martin
RE: DRTCP
Set the value in the Dailup (RAS)MTU box
eglwys
RE: DRTCP
I have looked through all the properties of my dial up but can't find anything marked RAS or MTU in fact nothing I can put a numerical value in. Am I looking in the wrong place?
RE: DRTCP
I've used the w2k version of drtcp but I can't believe the other versions are any different.
When you run DrTcp a pop up box opens that lists 'General Settings'
On the left hand side of this box it lists:
tcp recieve window
Window Scaling
Time Stamping
Selective Acks
Dail up (RAS) MTU
For PCI adapters enter your value of MTU in 'Dail up (RAS) MTU'. Typically a value of 1458 is good but 1430 has worked better for some people. Set 'tcp recieve window' to a multiple of the MTU less 40 (i.e. 1458-40=1418 times 10 = 14180). As there is some packet loss on the network at present if you drop this value it may help (try 12762 or 11344).
eglwys
RE: DRTCP
> Hi Cliff
Thanks for the replies
The problem that I have got is that my PCI modem is not listed in the adapter settings box nor is Dial up connection, Only- 1394 net adapter and Microsoft video/TV connection
Martin
> tcp recieve window
> Window Scaling
> Time Stamping
> Selective Acks
> Dail up (RAS) MTU
RE: DRTCP
> > Hi Cliff
It wont be, just change the dialup as that is what your PCI modem is.
Eg http://www.adp450.plus.com/pics/drtcp1500.jpg
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
Usually in #utgames #UT2003chat
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
eglwys
RE: DRTCP
Thanks Gus
I must be blind!
