DNS ?
stonechat
DNS ?
Hi
Very few site are reachable, when are these DNS issues gong to be fixed
Bob
Ritey
DNS ?
i suppose you could try using another isps DNS server until the problem is solved.
stonechat
DNS ?
I'm not convenced it is really a DNS issue
Ritey
DNS ?
nope me neither. I run DNS checks on many sites and the results are fine.
Trace router gives differing results depending on the web site:-
Resolving Host: www.mozilla.org...
[207.126.111.226]
Begining Trace...
TTL Host Ms Status
1 10.0.0.2 0 TTL_EXPIRED_TRANSIT
2 195.166.128.123 18 TTL_EXPIRED_TRANSIT
3 84.92.3.17 19 TTL_EXPIRED_TRANSIT
4 207.126.111.226 -1 REQ_TIMED_OUT
Trace Complete
FAILS
Resolving Host: microsoft.com...
[207.46.130.108]
Begining Trace...
TTL Host Ms Status
3 84.92.3.17 16 TTL_EXPIRED_TRANSIT
4 212.159.4.9 18 TTL_EXPIRED_TRANSIT
5 166.49.211.133 18 TTL_EXPIRED_TRANSIT
6 166.49.135.122 17 TTL_EXPIRED_TRANSIT
7 166.49.208.109 18 TTL_EXPIRED_TRANSIT
8 166.49.164.110 94 TTL_EXPIRED_TRANSIT
9 166.49.151.134 96 TTL_EXPIRED_TRANSIT
10 207.46.45.69 97 TTL_EXPIRED_TRANSIT
11 207.46.130.108 -1 REQ_TIMED_OUT
Trace Complete
SUCCESS
Resolving Host: google.com...
[72.14.207.99]
Begining Trace...
TTL Host Ms Status
2 195.166.128.123 19 TTL_EXPIRED_TRANSIT
3 84.92.3.18 18 TTL_EXPIRED_TRANSIT
4 166.49.211.9 17 TTL_EXPIRED_TRANSIT
5 195.66.224.125 17 TTL_EXPIRED_TRANSIT
6 72.14.238.248 18 TTL_EXPIRED_TRANSIT
7 66.249.95.146 92 TTL_EXPIRED_TRANSIT
8 72.14.236.219 105 TTL_EXPIRED_TRANSIT
9 72.14.232.111 122 TTL_EXPIRED_TRANSIT
10 72.14.236.130 128 TTL_EXPIRED_TRANSIT
11 72.14.207.99 103 SUCCESS
Trace Complete
SUCCESS
Resolving Host: ghostaholic.com...
[72.29.86.123]
Begining Trace...
TTL Host Ms Status
2 195.166.128.123 17 TTL_EXPIRED_TRANSIT
3 84.92.3.18 15 TTL_EXPIRED_TRANSIT
4 212.159.4.25 16 TTL_EXPIRED_TRANSIT
5 72.29.86.123 -1 REQ_TIMED_OUT
Trace Complete
FAILS
I dont think this is PN problem. Tho i dont think its to do with the connection drops either.
DNS ?
The DNS problems are beeing seen by many ISPs and is not PNs problem as the recent service status explains.
DNS ?
Hi, so does anyone know what's causing the dns issues and what's being done to fix it. The internet is virtually unusable for over 24 hours with mostly overseas sites affected...
Lyn
DNS ?
Hello,
I'm locking this thread in favour of this in an effort to keep all discussion in one place.
Chris
dragona
DNS ?
Even when i use IP addresses to connect to things it wont work.. i use a team speak server .. and that was inaccessable for half of yesterday even though i was usig an IP to connect...
I
f my undestanding is correct DNS only translates from a domin name to an IP so if IP's are used everything should be able to connect during DNS issues.
Am i wrong? or is this still just a DNS issue...?
I get frequent drops from WoW, Eve-Online and Teamspeak and they happen at the same time.
