DNS settings...
DNS settings...
This is just out of interest because the connection's working fine but...
The starter pack gives the DNS server settings as 212.159.11.150 and 212.159.13.150.
However, on the "connection settings" page of the plus.net portal it states that ADSL DNS servers are:
Primary DNS Server (ADSL) 212.159.13.49
Secondary DNS Server (ADSL) 212.159.13.50
Should I change this? Will it make any difference?
Brocco.
DNS settings...
The differance is that two new servers have been added since that documentation was printed.
All four addresses work, however, the older printed ones are now designated for dialup users, as they are physicaly located nearer the dialup platform.
The two newer servers are designated for ADSL, as they are physicaly located nearer that platform.
The differance is likely between 1ms to 1 second in a lookup.
If you are after perfomance, use the newer addresses, if you simply want to get it operational, follow the details provided.
DNS settings...
Cheers for that.
We'll all gamers here so every single ms helps... Wink
brocco
DNS settings...
Agreed.
[Moderators note (by Thomas): Unnecessary quote removed.]
