DNS problem
DNS problem
Morning Peeps,
Can anyone help meHuh I have an Asus 6000EV router connected to my switch and I seem to have problems with it. When I am browsing the web, after about an hour it drops out. I can still connect to the web via IP addresses, but if i type in a url I get page cannot be found. Plus.net say that their dns servers are fine.
I have also set DNS auto discovery on and off and manually set the PRI and SEC DNS address manually, but to no avail.
I haven't tried upgrading the firmware, as I've heard rumours about it's stability.
Can anyone help.
Many thanks in advance
Ricky Cross
RE: DNS problem
Do you have the problem if you assign DNS into each of your PCs?
DNS - primary 212.159.11.150
DNS - secondary 212.159.13.150
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Technical Support ................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: DNS problem
> Morning Peeps,
> Can anyone help.
> Ricky Cross
Thanks. This seems to have cured it.
One to customer support again!!!
