DNS heads up maybe a fix if Bt have been at your Exchange
Just got my DSL reactivated today and now BT has a different make of inline card at the exchange.
It used to be a Alcatel and now it's a Texas Instruments. I figured new card might need different settings so I tried using ANSI instead of the usual G.dmit that had worked well enough before.
Had two problems with it, repeated loss of connection and DNS failing on multiple sites.
So check what your inline card is identifying as, maybe BT Fixed your exchange and you now need to try different settings.
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
Usually in #utgames #UT2003chat
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
