DNS for my FTP Server
I have setup an FTP Server on my home LAN - I have setup correct Port forwarding in my router to the internal IP of the server hosting the FTP and I can access the Server externally from the Internet with no problems. now in order to allow cients to connect I have to provide them with my Static IP. This is ok but it would be better and easier for users to remember a DNS name e.g. 'ftp.mydomain.co.uk'. Whats the best way of achieving this that doesn't require users to specify my Public IP when connecting ? Is this sometging that I can configure via the 'DNS config' via my portal here on Plus Net's site ?
Hope Iv'e explained things clearly ?
Obviously I cant configure this on my local Win2k DNS box as this is not visible to the internet....!!
Thanks a lot guys
Craig
+Net don't just provide you with a static IP, but also with rDNS set on it to.
This means, that you can obtain a hostname from your IP and an IP from the hostname.
In the case of all +Net customers, this hostname is in the format <username>.plus.com, or in your case, ballistik.plus.com
However, if you have a domain on your account, you can point a sub-domain to your IP with an A record.
The host allready provided is the simplest though.
Yes this is.
Simply create an A record as follows
Left feild - ftp
Type - A Record
Priority - leave blank
Right Feild - your ip address
Wait a max of 24 hours for it to take effect (it might work in about 4 hours though).
Chris
Cheers for the info
EXCELLENT
Thankyou VERY much indeed for your swift replies
cheers Guys Smiley
