DNS error
DNS error
It happens very often lately, that the DNS goes missing and I have to disconnect from the service and then try to reconnect. And I say try, since I often get the error message of incorrect domain or password.
Would it make things easier if I just enter the primary and secondary DNS ip addresses instead of having them on auto?
RE: DNS error
I get the exact same problem m8 and its getting up my goat....
RE: DNS error
You dont have to use the Plusnet DNS addresses you can in fact use any service providers. I'd post the list of them but they are on my other PC at the moment. I usually use Demons as a backup as I have had this DBS problem a number of times. Search on the net for a list and you will find them quite easily then just replace the +net ones.
