DNS does not work automatically
ffupi
Since yesterday there is no internet connection.
Phoned customer support. After an hour disconnecting the modem they asked to check for http://217.147.177.11 . Because I could see this webpage, they said the automatic DNS server does not give to my router whatever it is.
Instead I needed to input manually into DNS-servers on the router (or under LAN-connection, TCP/IP on the computer):
212.159.13.49
and
212.159.13.50
With this the internet connection was back on.
Is this normal? :?:
1 REPLY
I actually had a similar problem after updating the firmware of my modem recently. It seemed to get the right address but did not assign the right address to my router/computer so i had to set it manually like you did.
