DNS Updates
DNS Updates
Hi
I have just changed some of my Domains to new hosts (well 4 days ago) and they have still no changed over. Am I right in saying that this should only take 48 hours?? Is there anything on a local level that could cause this problem, i have cleared my internet files and restarted my router to no avail
Regards
Aaron
DNS Updates
Are you sure all the changes were made correctly?
What changes did you make so others can check as well?
Most DNS changes propogate within 24 hours but sometimes it takes longer.
DNS Updates
Changed Atliberty.co.uk and fluiduk.co.uk to ns1.wehostyou.co.uk and ns2.wehostyou.co.uk
Kind Regards
Aaron
DNS Updates
All 4 plusnet DNS servers show the new IP:
C:\Documents and Settings\Peter>nslookup atliberty.co.uk 212.159.6.9
Server: ptn-cdns01.plus.net
Address: 212.159.6.9
Non-authoritative answer:
Address: 212.115.42.58
C:\Documents and Settings\Peter>nslookup atliberty.co.uk 212.159.6.10
Server: ptn-cdns02.plus.net
Address: 212.159.6.10
C:\Documents and Settings\Peter>nslookup atliberty.co.uk 212.159.13.49
Server: pth-cdns01.plus.net
Address: 212.159.13.49
C:\Documents and Settings\Peter>nslookup atliberty.co.uk 212.159.13.50
Server: pth-cdns02.plus.net
Address: 212.159.13.50
And the DNS servers for the domain are set correctly:
1	atliberty.co.uk	ALL	Query sent to	212.159.6.9
1 atliberty.co.uk SOA 86400 ns1.wehostyou.co.uk support.wehostyou.co.uk 2004111001 10800 3600 604800 86400
1 atliberty.co.uk A 86400 212.115.42.58
1 atliberty.co.uk MX 86400 mail.wehostyou.co.uk 10
1 atliberty.co.uk NS 86400 ns1.wehostyou.co.uk
1 atliberty.co.uk NS 86400 ns2.wehostyou.co.uk
1 Lookup complete
And Domain Dossier also finds it.
DNS Updates
Hmm just my pc then. .Any ideas what could cause it or how to fix it. Regards
Aaron
DNS Updates
What do you get with a nslookup and a tracert from your PC?
DNS Updates
Tracing route to www.atliberty.co.uk [213.171.192.236]
over a maximum of 30 hops:
1 * * * Request timed out.
2 46 ms 42 ms 39 ms lo0.plusnet.pth-ag1.plus.net [195.166.128.11]
3 26 ms 27 ms 27 ms gi1-2.vlan3.pth-gw3.plus.net [212.159.1.2]
4 29 ms 26 ms 25 ms ge0-1-0-22.ptn-gw1.plus.net [195.166.129.214]
5 65 ms 41 ms 39 ms gig-gw2-UK.cableinet.net [195.66.226.34]
6 28 ms 34 ms 69 ms 194.117.136.173
7 48 ms 53 ms 47 ms azt-tele1-pos.telewest.net [194.117.136.1]
8 * * * Request timed out.
9 34 ms 61 ms 51 ms 82.33.208.14
10 * * * Request timed out.
11 * * * Request timed out.
12 * *
DNS Updates
Try flushing your dns cache:
[list=1]
  • Click Start
  • Click Run
  • Type cmd
  • In the black window type ipconfig /flushdns
  • After this, again in the black window, type nslookup Atliberty.co.uk and see what it shows[/listShocked]
  • N/A
    DNS Updates
    That did it!
    thanks
