DMZ and port fwrd
DMZ and port fwrd
When i forward some ports for my computer on my lan to work with afew applications, my other lan computer that is a DMZ zone stops working? is there anyway to forward them ports and still keep the DMZ on?
1 REPLY
DMZ and port fwrd
Do you mean that nothing is now forwarded to the DMZ computer, or merely that things do not get forwarded to both the DMZ computer and the other one? {Have you not enquired about this in another thread?]
I don't know the specifics for your router, the Netgear DG814, but my expectation would be that if you set both a DMZ computer (X) and also specify certain ports to be routed to a different computer (Y), then for those ports (Y) would receive the packets and (X) would not, but for all other ports not otherwise specified, (X) would receive the packets.
