DG834G and UT2004 - AARRGH!!!
Hi there
I'm at my wits end with this router!
I've been onto the Atari forums and various Unreal forums and had lots of help but STILL cannot get people connected via my dedicated server game!
I can connect locally over my LAN and it is advertised on the MasterBrowser but shows no stats and ping is N/A.
Heres some info:-
XP Firewall is off on all pc's my side.
Latest 3323 patch for UT2004 on all my PC's.
ServerBehindNAT=True
I was advised to change the 7777 port to something less standard, so opted for 10101.
IP address my side for PC hosting game = 192.168.0.5
This is what I have the router configured for at the moment.
Incoming
7777 to 7788 UDP > 192.168.0.5
10101 TCP > 192.168.0.5
Outgoing
7777 to 7788 UDP > 192.168.0.5 (allow any WAN traffic)
11777 UDP > 192.168.0.5 (allow any WAN traffic)
28902 TCP/UDP > 192.168.0.5 (allow any WAN traffic)
10101 TCP > 192.168.0.5 (allow any WAN traffic)
If you require any more info please let me know.
Cheers
Alan
you made One mistake, the Server 10101 port is UDP not TCP the only TCP port is for the master server handshake port.
So would recommend you reset the ports to the standards until you get it working and Then customise it.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Thanks - will try that and report back...
Moderators note (John) Quote removed. Please don't quote thre preceding post in full. There is no need.
Still no go...ports set back to default.
All sorted now - went back to the drawing board with clean .ini files and cleared out my router rules - all running fine now. What a nightmare!
Cheers for the help.
Alan
