D-link DSL-300G+ problem
As anyone else had this problem? When I try to change any of the modem settings I get to the log in page but get the error message:-
Protected Object
This object on the RomPager server is protected.
Return to last page
With the modem as it is I can connect to the net OK but I'm thinking of going X-box live so I may need to change the settings.
Has of yet I have not had a reply from D-Link customer support.
A window should have popped up before this asking for a username / password. I get that error if I enter the password incorrectly. Maybe try a different browser?
Thanks but i don't get get that far, as soon as I click on the
Login to the web-based management module link I get the error message.
I will try another browser though.
Yeah, on mine I click Login and the window pops up. It may be that the browser is caching an incorrect password or something. Trying another browser should work. Out of interest what browser are you using?
I'm using internet explorer version 6
Hmm that's odd. I would of thought it would work perfectly on IE.
