D-Link G604T Help needed
Hi
Just moved to this Router/Modem from the Voyager 105 modem. Previous to moving we had 2 computers linked via ethernet and worked fine. Connected up the G604T, internet fine on main computer, but now the other computer cannot access the net or the main computer. I used the cable we already used and just connected it into the G604T. I have even assigned the computer its own IP address but still not allowing it access to the net or main computer. Also main computer cannot see the other computer.
New to Router/Modem so any help greatly appreciated.
If I have understood this right, previously you connected computer to computer via ethernet, now its ethernet to router.
I think that one way you need a 'straight' ethernet cable, the other 'crossed' so you will not be able to use the same cable. I have the same set up, 2 computers ethernet, 2 wireless and no problems, all talk to each other and the internet.
Thanks for the info, have solved it. It was issue with the cable.
