D-Link DSL300G+ Modem and DI-624 Router
I have just purchased the above modem and router to replace my current Netgear DG824M.
Has anyone else got either of these two running on their dsl connection and know of any ways of getting the damn things to work!
Starting to pull my hair out at the moment cos I couldnt even get the connection to work using a direct link from my pc to the modem.
Have a look at this topic disccussed a while back, 2 users managed to get the set up going. The bit about firmware updates via D-Link UK will help with any
MTU problems, so don't bother with the network optimizer.
http://portal.plus.net/central/forums/viewtopic.php?t=9436
thanx for the quick reply - most appreciated
hi, got a dlink 300g+ and a netgear rp114 routher if this helsp at all
cheers
j
