D-Link DSL 504
D-Link DSL 504
I have just bought a second hand D-Link DSL 504 router of Ebay because my Sitecom router was completely freezing when I was using BitComet.
The D-Link is working fantasticaly so far. The only problem is that it does not have an automatically reconnect option like the Sitecom did. I need this as I have an FTP server set up at home that I use for work.
Does anyone know about this router and if there is anyway I can make it reconnect automatically if the connection drops. It currently will connect on local demand which is no use if I need to connect remotely.
D-Link DSL 504
hmm it should do, mine always use to reconnect automatically, not sure where/if there is a selectable option, there should be, probably in the Multiple PPP or whatever it is, but im certain it always use to reconnect itself if the connection dropped
D-Link DSL 504
It probably will automatically reconnect. I would just rather it had an option just to make sure. Really starting to like it now. I have been abusing it with BitComet for 24 hours now and working fine. My old one would have long since frozen!
