Current connection speeds url
Proclus
Could someone tell me what the url is so you can check the current max limit your adsl is set at.
It's something https://portal.plus.net/my.html?action=Huh?Huh?
My router orginally reported that my adsl speed was 8128 then it went down to 7628 now its 6368. My upload speed has stayed at 448.
Although i never get these speeds the best i get on downloads is 200.
matrox
https://portal.plus.net/my.html?action=stable_rate&pn_session=a82c6ad53180fff60d0d928ed26d3ba7
and their speedtest is,
http://portal.plus.net/my.html?action=bandwidth_test
I only have this because I bookmarked it, God alone knows how you could possibly find it any other way.
Proclus
noelwilde, that's exactly what i was looking for. Your right, if you don't bookmark links like that, you will never be able to find them again.
I def' think, that they should put a link to my.html?action=stable_rate in My Account > Connection Settings area of the Members Centre
Anyway, noel thanks again for your help. Wink
Matrox
You're welcome Matrox, we're all in the same boat, swishing around without a captain, oh God! Are they rocks I see?
The more memorable
http://portal.plus.net/my.html?action=stable_rate
will do the trick. Cheesy
