Could my Router really be causing these speeds ?
Fantasticfourum
I am staking all my hopes on a change of Router that PN will hopefully deliver next week. My question is could my Router really be causing the following speeds, it seems like i'm getting slower and slower, i might as well use a 56k modem.
Date Speed Achieved (kbps)
28-04-2007 20:47:47 99.5
28-04-2007 20:47:07 98.2
28-04-2007 20:46:20 138.3
28-04-2007 20:45:46 172.9
28-04-2007 11:12:10 248.7
28-04-2007 08:28:54 298
27-04-2007 22:52:52 476.3
27-04-2007 14:18:19 478.8
27-04-2007 12:21:21 484.9
27-04-2007 10:50:24 480
26-04-2007 14:14:49 492.2
25-04-2007 22:02:56 2823.5
24-04-2007 15:48:57 1918.9
23-04-2007 19:30:19 964.6
23-04-2007 17:24:04 930.3
23-04-2007 17:23:00 981.8
23-04-2007 14:06:39 2545.2
23-04-2007 09:14:50 211
22-04-2007 20:12:41 898.8
Are these eratic speeds or what ?
I still cant fathom out what could be causing the re syncs as this is not an isolated occurence this is all the time.
How can i go from 211 kb to 2.5 mb then down to 981 kb etc etc I suppose i want someone to tell me yes i had the same problem until i changed my router and Bingo !
The BT speed test makes even worse reading:
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 250 kbps
DSL connection rate: 448 kbps(UP-STREAM) 896 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 58 kbps
Routers are better as they dont rely on the o/s but I wouldnt expect miracles. Your performance suggests something sadly wrong which may be related to the weather or other external event. We need your line stats etc
Fantasticfourum
How do i get my line stats ? Thanx for the reply
Plusnet Staff
Plusnet Staff
This page shows how to get the stats on most hardware:
http://www.kitz.co.uk/adsl/frogstats.htm
Certainly I would say that resyncs are causing the lower speeds because it's resync'ing at a lower rate which is lowering the IP profile.
If you haven't had a look at this:
http://usertools.plus.net/tutorials/id/13
it's worth a read to see if anything there helps as well.
