Connectivity
Connectivity
Morning.
I know it's a bit early to ask.
but is anyone else online?
i have been having connection problems since 6am.
My ADSL dectector GREEN light keeps going from solid GREEN to a flashing GREEN and i get cut off.
I know it sounds like problems at the local exchange, or my drivers are messed up on my PC.. or the USB link lead is damaged..
But thought id ask before i change things.
Thanks.
Jason
RE: Connectivity
I was cut off three times just after posting the above!. every 50 secs or so im disconnected.
Sad i think since it's the GREEN ADSL dection light that flashes and i then cut off line. it sounds like my exchange is having problems.
But im going to re-install my modem drivers anyway.
fingers crossed.
Jason
RE: Connectivity
Just back! i re-installed the drivers, rebooted.. no luck.
So powered off computer and disconnected line for 30 mins, and placed modem in bathroom (b/c its cold in there)
Now re-booted up, but im still losing the GREEN light now and then and getting cut off.
It was worse b4, i can hardly stay connected for 50 secs at a time, once disconnected the GREEN ADSL dectector light flashes, then locks SOLID GREEN again, then flashes then locks.. etc.. you can reconnect in between times but get kicked off when the light goes out.
Dont know if there is a problem with BT.. as it's a bit early, but if not then my exchange has a problem. and i guess im off ASDL for now Sad
Jason
RE: Connectivity
PS> before i go off again.
My modem is D-LINK DSL 200.
Jason
RE: Connectivity
Hi Jason,
Sorry i havent had any of the problems you have been experiencing. I logged in at about 8:45 and its been fine.
Dave Allan
RE: Connectivity
> Hi Jason,
> Dave Allan
Yup solid here as well Jason so it looks like something at your lacal exchange is playing up.
Cry
RE: Connectivity
> Morning.
> Thanks.
> Jason
Yes me to,repeated disconnections, the best thing to do is switch off!
RE: Connectivity
Same here ... for a few days now ;(
Where are you? (What's your local exchange?)
I'm in Putney (London SW15).
Axel
RE: Connectivity
> Axel
Milton Keynes!!
RE: Connectivity
I'm on the 'Cumbernauld' exchange mate.
it's 15 miles outside of Glasgow, Stirling and Edinburgh. right in the middle of nowhere Smiley
Everything is OK now, i eventually gave up at 8am ish.. then came back online just after 1.20pm so had a 5 hour break, and the light is rock solid green now.
So maybe just a glitch with the exchange early this morning. hope so anyway.
Jason
RE: Connectivity
Very odd... .
Well, I've spoken to BT and PlusNet, both promised to look into it. Some hope that.
PS: I've had this problem all week, since last Friday (as far as I remember).
Axel
dhumble
RE: Connectivity
Hey Miky!,
I'm in Bletchley, Milton Keynes and not had any problems at all this weekend. Been busy setting up MySql here.
David
RE: Connectivity
> Hey Miky!,
> I'm in Bletchley,
So am opposite Furzton!
Miky
VixousVixen
RE: Connectivity
>Im in Fulahm about 10 mins away from you Axel and I've had No problems here (touch wood)
