Connections on same gateway issue
oliverb
I thought the issue with connections between systems on the same gateway had been cleared up.
The tracert results I've just had say otherwise. Ping of 520ms when both are on ptn-ag1 and 42ms when one is moved to pte-ag1
1 REPLY
http://portal.plus.net/central/forums/viewtopic.php?t=51989
Same Q asked 2 days ago, nothing reported back yet.
I'll try to get an update from someone.
