Connection?
astraweb
Connection?
Having been with Plusnet 512 Premier for 15+months Cheesy , and in the near future will be getting a newer computer, XP 3.2 etc; do I need to be aware of anything, or just load the software as I did when I joined Plusnet? Thanks.
1 REPLY
Connection?
You dont say how you are connecting ie modem or routerr. If a modem what type?
If its a router you only have to set up the network. If its a modem you install the drivers as before. If you are on win98 make sure you have the XP drivers and check the forums to see if there are any problems with your modem on XP
