Connection stopped
Connection stopped
I have had adsl for a few weeks and today is the second time I cannot connect. The green connect light is on the Netgear 814 router but it won't work, even after router and PC reboot. Been like it all evening. Glad I have a modem!
Andy
RE: Connection stopped
have just gone adsl with a netgear 814 - green light is active but can't connect - any thoughts
> Andy
Did you find a soltion.
Mine does the same :-(
Pete
Unplug it and leave it off for awhile. The router itself has a few bugs on authentication. I believe there is a firmware upgrade which can be downloaded from the manufacturers website. This patch may fix your issue.
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| PlusNet Customer Support .......... for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
