Connection speeds
Connection speeds
I have just run a speed test which shows my 2MB connection is working at 38kbps! The test page prompts me to change my settings - howHuh
1 REPLY
Connection speeds
Which speed test did you try? It doesn't sound like a very reliable one, I'd suggest trying http://www.adslguide.org/tools/speedtest.asp
Also try the plusnet speed tester.
