Connection problem
weatherman
Connection problem
Sad I am having trouble setting up my connection I have a ex BTOPENWORLD Intel Anypoint DSL usb modem 3240, are thes modems pr-programed to connect to BT or is there some way to convert it to work with PlusNet or do I have to buy another modem?
So I bought another modem and all's well now Tongue
1 REPLY
Connection problem
Try uninstalling the software then downloading the lastest drivers from here.(click on th elink at the bottom of that page to see all links related to that modem).
It does look like the product is geared towards BTO but in theory it should work fine with any ISP (this is a guess though as I have never used it), you just have to change the login & password on it for PlusNets instead of BTO.
